ABS Diagnostic Port Specific
Old Sep 5, 2009 | 09:00 AM
isofast's Avatar
Default ABS Diagnostic Port Specific
Hello forum I just recieved ABS amigo in the mail.
I have a 2003 Discovery
Four questions for three amigos
1). Is the port for abs amigo at passenger side footwell?
2). If so any tricks to getting the trim off with out screwing it up?
3). Disco need to be switched on or running to recieve and clear codes?
4). Has anyone tried their ABS Amigo scanner with a MACBOOK?
Here is the ABS Amigo baseline printout prior to hook up to the truck.
Thanks for all the help. This forum is great.
Ernie
File Type: txt
Old Sep 5, 2009 | 11:06 AM
lipadj46's Avatar
You plug it into the regular ODBII port under the steering wheel (assuming you are in the US). It did not come with instructions?
Old Sep 5, 2009 | 11:23 AM
isofast's Avatar
No instructions.
And thanks for your reply to question #1 and 2
Any idea on 3 or 4?
Thank you, very much.
I think this forum is great.
Ernie
Old Sep 5, 2009 | 12:33 PM
isofast's Avatar
Default False Positive
Can anything trip to cause a shuttle valve fault?
Intermittent 3 amigo light everything works fine.
2003 Disco 2
Scan with abs amigo looks like this, and yes it works with a Macbook!
File Type: txt
Old Sep 5, 2009 | 01:32 PM
So where are you know as far as the 3 guys?
How are your brakes, are they squeaking?
Old Sep 5, 2009 | 02:46 PM
lipadj46's Avatar
Looks like you should try this kit:
http://www.jewellamberoil.com/sales/...roducts_id=190
If that does not work you may have to tear into the ABS module and re-solder a connection.
isofast's Avatar
Hi Mike yes brakes at one time squeaked but not any more. I replaced the brake pads even though they were fifty percent. Rear drivers side hub leaked a little so I changed rear gear oil to 145 weight with one ounce of White Shepperds no more leaks or squeaks.
I have not driven the Disco since I reset the three amigos with the ABS Amigo.
I asked the wife what occurs just before 3 amigos and she said hard braking. I have never seen these three guys appear while I was at the wheel.
Ernie
ljdiscovery
Oct 29, 2014 03:53 PM
Macbeth
Apr 2, 2013 08:52 AM
tootie
Jan 31, 2011 10:44 PM
Malafax_Dand
Mar 30, 2009 06:31 PM
alanroberts50
May 30, 2008 03:21 PM
