ABS Fault
ABS Fault
I have the below faults on my ABS, from an ABS Amigo. They are intermittent, they show up every once in a while, which makes me think it is actually lose wire or similar. I also have the red brake light on intermittently.
Seems like the fault would be in the wiring near near the ABS unit?
Any thoughts?
..--Previous Faults--->
Active Faults:
None
Logged Faults:
045:Rear Left sensor output low
047:Rear Right sensor output low
Rear Right Sensor Bad Output
114:Shuttle Valve Electric Failure
Any thoughts?
Active Faults:
None
Logged Faults:
For the sensor faults, the problem is often the connector where the sensor pigtail connects to the wiring harness. Best4x4 advocates splicing in butt connectors to address the known problems with the connectors, but I tried something even less invasive and it's worked for me.
Locate the connector (the rears are easy once you remove the wheel), disconnect it. A flat blade screwdriver is useful to pry apart the two halves of the connector. Then, using needle nose pliers, try crimping the metal parts of the female half of the connector slightly to improve contact. I do still get faults intermittently but infrequently.
As for the Shuttle Valve Electric failure code, do Option B.
I also recommend a set of 2 wire trailer plugs if you still want the ABS sensors to have connectors vs being solid with the 3M butt splice connectors. Option B should take care of the Shuttle Valve fault.
In TX or hot climates the OEM connectors will basically just crumble away. Whatever you do you just need to repair those bad connectors be it with 3M butt splices, 2 wire plugs, or even fuel injector harnesses. You just want a good solid connection on the 2 wires. Polarity is not an issue. Just make sure the connections are good and solid and sealed from the elements.
Thanks for the response. I did the option B last year and it is mostly effective, about 1-3 times a year for a short while the three amigos pops back up. I replaced the master cylinder and bled the brakes last year, I wonder if that caused my new problem, disturbing something while bleeding.
Ill take a look at the connectors.
seaosrover
10-23-2010 01:48 AM
