ABS Fault
Old May 21, 2020 | 10:39 AM
redrover75's Avatar
Default ABS Fault
I have the below faults on my ABS, from an ABS Amigo. They are intermittent, they show up every once in a while, which makes me think it is actually lose wire or similar. I also have the red brake light on intermittently.
Seems like the fault would be in the wiring near near the ABS unit?
Any thoughts?
..--Previous Faults--->
Active Faults:
None
Logged Faults:
045:Rear Left sensor output low
047:Rear Right sensor output low
Rear Right Sensor Bad Output
114:Shuttle Valve Electric Failure
Old May 21, 2020 | 12:25 PM
mln01's Avatar
For the sensor faults, the problem is often the connector where the sensor pigtail connects to the wiring harness. Best4x4 advocates splicing in butt connectors to address the known problems with the connectors, but I tried something even less invasive and it's worked for me.
Locate the connector (the rears are easy once you remove the wheel), disconnect it. A flat blade screwdriver is useful to pry apart the two halves of the connector. Then, using needle nose pliers, try crimping the metal parts of the female half of the connector slightly to improve contact. I do still get faults intermittently but infrequently.
As for the Shuttle Valve Electric failure code, do Option B.
Old May 21, 2020 | 01:34 PM
Best4x4's Avatar
I also recommend a set of 2 wire trailer plugs if you still want the ABS sensors to have connectors vs being solid with the 3M butt splice connectors. Option B should take care of the Shuttle Valve fault.
In TX or hot climates the OEM connectors will basically just crumble away. Whatever you do you just need to repair those bad connectors be it with 3M butt splices, 2 wire plugs, or even fuel injector harnesses. You just want a good solid connection on the 2 wires. Polarity is not an issue. Just make sure the connections are good and solid and sealed from the elements.
Old May 22, 2020 | 08:29 AM
redrover75's Avatar
Thanks for the response. I did the option B last year and it is mostly effective, about 1-3 times a year for a short while the three amigos pops back up. I replaced the master cylinder and bled the brakes last year, I wonder if that caused my new problem, disturbing something while bleeding.
Ill take a look at the connectors.
Old May 22, 2020 | 09:04 AM
Best4x4's Avatar
Did you replace the shuttle valve switches when you performed Option B? I personally replace them while I'm in there. 90% of the time if the 3 Amigos come on & then go off with a key cycle = shuttle valve switches, brittle wiring to them, or a bad ground with Option B mod.
Old May 22, 2020 | 12:09 PM
whowa004's Avatar
If changing out connectors it might not be a bad idea to lengthen the wires as well. I am constantly ripping my rears apart when off-roading and just haven't gotten around to lengthening/improving them.
dparham
Jun 26, 2018 08:14 AM
dr. mordo
Feb 7, 2015 09:29 AM
caymandrew
Mar 14, 2013 02:03 PM
sayeedA
Dec 14, 2011 10:37 PM
seaosrover
Oct 23, 2010 01:48 AM
