ABS Fault
Old May 10, 2018 | 07:03 PM
redrover75's Avatar
Default ABS Fault
Logged Faults:
033:Front Left out valve open circuit
034:Rear Right in valve open circuit
035:Rear Right out valve open circuit
074:Rear Right in valve short to supply
Does this sound like the shuttle valve or the the right rear speed sensor?
any thoughts?
I have not done either repair on the abs unit yet.
Thanks
Old May 11, 2018 | 10:17 AM
Twix's Avatar
Option b, probably replace the valves themselves as well if they're leaking
Old May 11, 2018 | 08:10 PM
CollieRover's Avatar
It’s been a while since I dealt with this, but it sounds as if your valves are leaking, and if you take them out you can see the brake fluid in them. You may as well do option b at the same time. I got my kit at Falconerrks for the rebuild. Worked like a charm.
Old May 11, 2018 | 08:32 PM
JUKE179r's Avatar
Originally Posted by CollieRover
... I got my kit at Falconerrks for the rebuild. Worked like a charm.
ABS shuttle valve code solution; brake fluid leaks
Old May 12, 2018 | 11:12 PM
redrover75's Avatar
Default Fix
I'll do the b, I have replaced the shuttle valve on other trucks. Never had a fluid leak.
I have a hard time paying their ask for a couple rubber rings.
very intermittent, will probably end up being a hub.
Old May 13, 2018 | 01:21 PM
dparham's Avatar
I do have a question too not to take over the post as this may be a little helpful... i too have an 044 code right side abs sensor falure with the amigousb device... which side is considered the Right side? lol right as from sitting in the seat or right as right side facing the engine? lol
Old May 13, 2018 | 03:25 PM
OffroadFrance's Avatar
Originally Posted by redrover75
Logged Faults:
any thoughts?
Thanks
It sounds like a case for Option B and replacement of the shuttle valve seals. They are available in the US from Falconworks. Pricey, yep, but there are no other options as WABCO won't sell you them, I've tried! Don't forget to power bleed the primary system after fitting them or you'll gain nothing. Whilst doing all this also replace your old master cylinder and reservoir also. Get your hands on a good brake nut spanner before you start and also some bleed nipples as usually they are very rusty.
06Range
May 8, 2013 09:01 PM
jmason
Mar 12, 2013 08:08 PM
anhernandez
Aug 18, 2009 12:47 AM
cottonpatchweims
Jan 14, 2005 01:59 AM
