ABS & fliud
Old Nov 23, 2007 | 10:28 PM
discoboyd's Avatar
Default ABS & fliud
1995 Discovery,
We have lost the brakes a couple of times during the last two months.
Both time we sent it to a dealer for service. New pads & fluid all lines have been checked.
About two days ago the ABS light came on. Is there a recomended process for checking the brake system?
What is the primary cause for the ABS light to come on? Is it something I can fix or do you recommend the dealer?
Old Nov 24, 2007 | 08:59 AM
Default RE: ABS & fliud
My ABS light is on too, it is adirty wheel sensor. The last person to have brakes put on my truck used cheap pads and all the brake dust mess' up the wheel sensors. Since the dealer did the work take it back to them and have them check it out at no charge. Because all was fine before they did the work I wouldnt let them charge to look at it.
If you need to make a scene in the waiting room then so be it, but the should not charge you.
Old Nov 24, 2007 | 09:13 AM
On your 95 Disco, What brand of brake pads are you using, are they squeaking or dusty, was sound deadening material used on the new pads ans was the brake fluid just checked or were they flush completely with new brake fluid?
angusm23
Jul 30, 2009 06:29 AM
dammad
Jan 26, 2009 01:50 PM
cottonpatchweims
Feb 10, 2005 07:18 PM
cottonpatchweims
Jan 14, 2005 01:59 AM
