ABS light on after pumping brakes
Old Sep 14, 2008 | 12:23 PM
nitrocharger's Avatar
4wd High
Default ABS light on after pumping brakes
The 3 amigo problem is intermittent. Usually the lights are off when I first start the car. When I pump the brake pedal in parkI can sometimes get them to turn on. I'm assuming this means that my wheel sensors and brakes are probably ok but the real problem might be in the valves. Would the valve rebuild kit from Atlantic British fix this problem? (its a 2003 Disco)
Old Sep 14, 2008 | 01:06 PM
roverguy7's Avatar
Default RE: ABS light on after pumping brakes
how much are you pumping it... its designed that if you pump it 10 times in less then 10 seconds right after start, it will disable abs, hence the lights... make sure youre not causing the problem... and get your codes read, dont just guess at how to fix it if you have no idea what is wrong
Old Sep 14, 2008 | 07:18 PM
4wd High
I didnt know about pumping them 10 times turns the ABS off but I'm only pumping them 2 or 3 times.
Old Sep 14, 2008 | 07:30 PM
roverguy-is that for every car or just LR's? I never knew that.
Old Sep 20, 2008 | 08:50 PM
roverguy7's Avatar
just discos, not even sure if d1s have it, but on a d2 if you pump the pedal quickly after startup itll turn on your lights, and will be out for the rest of the key cycle
Old Sep 21, 2008 | 09:08 AM
Quit trying to figure out something you have no way of testing.
Go do one thing today and get back to us, do 2 pqanic stops from 30 MPH and see if you can feel your ABS pulsate thru the brake pedal, if you can, this is good. While doing this, pay attenetion to your brakes, do they squeak when braking, if so, this is your broblem and they will need to be cleaned or replaced prior to correcting the on again off again trio.
DadOfRoverOwner
Jan 16, 2021 07:32 PM
A5scott
Sep 9, 2011 10:35 PM
RamblingMan
Dec 10, 2009 06:34 PM
airic
Jan 18, 2009 08:07 AM
