ABS light on...? No codes...??
Old Jan 2, 2016 | 02:42 PM
RSDEVIL's Avatar
Default ABS light on...? No codes...??
Just as the title says... The ABS light is on yet there are no codes in the my scanner. I searched ABS / Discovery II section and no matches...?? Any help would be appreciated...!!
Old Jan 2, 2016 | 03:17 PM
abran's Avatar
You won't get a engine fault code. You need a specific Land Rover scanner that reads ABS codes.
Old Jan 2, 2016 | 05:00 PM
RSDEVIL's Avatar
It's a pretty expensive 2014 Snap-On Solus Edge. It communicates w Anti-Lock Brakes and gave me codes 119 Front Left Sensor (Output Intermittent) & 134 Shuttle Valve Switch (Electrical Failure). I cleared it to see what comes back and codes are gone (for now) although the ABS light is still on.
Old Jan 2, 2016 | 09:38 PM
abran's Avatar
Did the light go off when you cleared it? Maybe it's a "hard fault". Did you fix the issues, or just clear the codes?
Old Jan 2, 2016 | 11:44 PM
toofaroffroad's Avatar
ABS Amigo....get one. They are a "must" for D2 owners.
Old Jan 3, 2016 | 10:15 AM
dr. mordo's Avatar
I think your Snap On scanner will do what you need.
The Shuttle Valve switch is a common failure -
You want to do OPTION B
The left front sensor issue is a can of worms. Could be the sensor, hub (wheel bearings), wiring, or SLABS (ABS Computer).
Good luck. I've had a similar problem with my left rear for the last year and still haven't cracked the code.
Old Jan 3, 2016 | 03:32 PM
RSDEVIL's Avatar
Thanks Again Dr. I did find that link on my own doing some late night searching. It appears someone has already been probing around as my entire ABS unit had junkyard #'s written on it w a marker and my harness is somewhat unwrapped.
Ohhh and the ABS light did go out as soon as I started driving. (For now)
04SSHD
Apr 11, 2012 06:20 PM
marlymarl
May 28, 2011 10:34 PM
yuenie
Jan 13, 2010 05:37 PM
BajaXJ92
Dec 3, 2009 07:43 PM
cottonpatchweims
Jan 14, 2005 01:59 AM
