abs modulator
Need Help:
About three mouths ago i saw that three amigos light poped on tc/abs/dh. i took it in to the dealership and they said that it's a bad abs modulator and it would cost about $1900 to fix. After read some comments on the forum so people said that it might be the sensor i was wondering if someone can tell me were can i find the front and rear sensor to see if that is the problem.
thank you
thank you
You can trace the ABS sensor lines to the sensor. For the front it is located nearbetween the wheel hub and the coil. For the back, it is on the back side of the hub housing (installed horizontally). Some times the sensors back out and you can push them back in. Other than that, not much to inspect. FYI, the manual recommends installing new bushings if you remove the sensor. Good luck.
