ABS MODULATOR FIX (NO more SVS fault)
Old 03-10-2012, 01:33 PM
matt3502's Avatar
Default readings ABS codes
You need a code reader that scans the ABS codes like the ABS amigo from RSW solutions.
  #82
Old 03-12-2012, 02:24 PM
dgh's Avatar
dgh
dgh is offline
That's correct. The truck does the standard codes - check engine stuff for example - withe the standard code reader. Butif you want the abs codes you need a special reader. There are other causes for the Amigos and unfortunately you might have a different issue.
Guys on the forum have worked deals to rent or loan their readers. I've got one and if you are in New England maybe we can work something out.
  #83
Old 03-12-2012, 08:45 PM
shj3c905's Avatar
I got the codes read and cleared. NO MORE 3 AMIGOS!!! Woohoo and finally. Thanks guys for the input and thanks VI for the excellent instructions.
  #84
Old 03-13-2012, 07:18 AM
shj3c905's Avatar
Spoke too soon. Taking my daughter to school this morning and they all of the sudden popped back on. Any suggestions?
  #85
Old 03-13-2012, 07:56 AM
matt3502's Avatar
What codes did you get when you had them read? I have had the three amigos off and on for a while now, and I always pull the same code: 114:Shuttle Valve Electric Failure. I have done Josh's Option B repair, but I still have them. For me I think it is due to a poor connection at the shuttle vales which I am going to rework ASAP. Check this link out and it may help you understand what is going on:ABS shuttle valve code solution; brake fluid leaks
  #86
Old 03-13-2012, 02:55 PM
dgh's Avatar
dgh
dgh is offline
Matt's right...you gotta get the codes. Here's an abs amigo reader for sale by another member...
https://landroverforums.com/forum/di...r-codes-48144/
  #87
Old 03-13-2012, 05:37 PM
shj3c905's Avatar
Default ABS Code Reader
Thanks dgh for the info. I just emailed him.
  #88
Old 03-13-2012, 06:54 PM
DonRW2007's Avatar
Default ABS Amigo
For what it's worth, I will rent mine for just the actual shipping cost. Send a $125 deposit via PayPal; I will refund less the $3-$4 upon return. Have done a half dozen or so times for members of the forum...
DRW
  #89
Old 03-14-2012, 12:57 PM
shj3c905's Avatar
Thanks Don for the offer. It tbesselman has already sold his I would be grateful to take you up on your offer. I will let you know whenever I hear back from my email to tbesselman.
Steve
  #90
Old 03-18-2012, 06:10 PM
shj3c905's Avatar
Default AMIGO ABS for D2
Before I borrow one, does anyone have an ABS Amigo for D2 for sale?
Quick Reply: ABS MODULATOR FIX (NO more SVS fault)
