Abs modulator install question
Old Mar 19, 2012 | 04:02 PM
mx468's Avatar
Default Abs modulator install question
Okay, I'm about to install a brand new used abs modulator in my disco 2, is there anything I need to know before installing, other than take old modulator out, put new one in reverse order, and than bleed brakes? Do I need to hook it up to a pump of some sort etc.. And if I had my local Indy rover mechanic do it, how long should it take? Cost of job? thanks!
Old Mar 19, 2012 | 04:42 PM
jafir's Avatar
It's pretty much that easy. What's wrong with your current one? I'd do the svs fix in the stickies too while it's out.
As far as bleeding goes, you may have better luck bleeding at the modulator first, then bleed at the wheels. I couldn't get any pedal pressure until I bled the lines going from the master cylinder to the modulator. Then I used my hawkeye to bleed everything else, but you can use the normal method instead.
Old Mar 19, 2012 | 07:15 PM
mx468's Avatar
I broke a hex screw while trying to attempt the svs fix and was going to retap it but I saw a new used modulator for 35 and so I bought that one, took it apart, checked all, changed shuttle valve orings with falconworks and did the svs fix, just waiting to install it. My old modulator needs new shuttle valve and screw to be retaped. Probaly will sell it for parts. Thanks for getting back to me.
RoadDog
Jun 6, 2015 07:49 PM
RoadDog
Jun 6, 2015 07:26 AM
04duxlr
Jan 8, 2014 04:22 PM
stanigu
Jan 21, 2007 02:25 PM
rebooTT
Jun 20, 2005 01:09 AM
