ABS Shuttle Valve
Old Nov 5, 2008 | 06:27 PM
1sttimediscoII's Avatar
4wd High
Default RE: ABS Shuttle Valve
I am experiencing the three amigos intermittently (rarely now, but fear it will get worse). I have two faults "shuttle valve switch electrical failure" and "rear, right outlet valve has short to internal power supply". The mechanic is recommending a new modulator. He claims that replacing the shuttle valve is short term because the root cause is a leak in the modulator onto the shuttle valve sensor.
Are those who have replaced the shuttle valve only seeing the proble return?
Thanks
Old Nov 5, 2008 | 06:45 PM
From what I understand replacing the shuttle valve with the GOOD repair kit cures 90% of the shuttle valve problems.
Using the cheap kit is a temp fix.
The good kit replaces all of the internal parts.
Old Nov 5, 2008 | 07:03 PM
4wd High
How can I make sure I get the right kit? Is it the shuttle valve kit $80 vs. the modulator valve kit $800? Or, are there different versions of each kit?
Thanks for the quick response.
Old Nov 5, 2008 | 07:12 PM
http://www.roverparts.com/Parts/SWO500030G.cfm
http://www.roverparts.com/Parts/SWO500040G.cfm
These are the two kits, as far as I know there are only the two.
Old Nov 5, 2008 | 07:27 PM
4wd High
Thanks again!
Old Nov 6, 2008 | 09:40 AM
The first kit made available, the cheap one, had a terrible success rate in the low 20% range, the more expensive kit had much better results.
You can also go to, http://www.roverlandparts.com/absmodulators.aspx and get a good guaranteed used replacement for $795, which if mine were to fail I would buy.
Old Nov 6, 2008 | 10:49 AM
4wd High
Great information.
It looks like the part you reference is a complete ABS Modulator not a repair kit for the same price as the repair kit Spike555 referenced. I am guessing it is rebuilt. I think for the same price that is the way to go.
I have read in other forums that after replacing the parts and bleeding the brakes (myself), I still need to take the truck in to have the fault codes cleared. Is that really necessary? Is it to confirm the repairs worked?Unless it will result in future problems, I do not mind fault codes in the history. I also saw a reference with a link to a "RAVE" manual that I think I need, but can't find it now.Does anybody have the link?
Thanks
Old Nov 6, 2008 | 01:06 PM
Disco2Guy's Avatar
RAVE:
http://www.lrrforums.com/showthread.php?t=7569
More 3 amigos info from RoversNorth:
http://www.roversnorth.com/web/downl...R_ABSfault.pdf
bosshogt
Feb 2, 2012 06:52 PM
aarongregor
Nov 14, 2011 08:31 PM
majrmike
Oct 9, 2007 03:13 PM
Different Drummer
Aug 7, 2006 09:28 AM
rovernbama
May 9, 2006 11:12 PM
