..:: The ABS Situation ::..
Old Oct 11, 2019 | 07:22 PM
adolfojbonilla's Avatar
Originally Posted by mln01
Yes, a "broken" ABS sensor will trigger the Three Amigos. And anytime the Three Amigos appear you're going to get the 1590 code. But what exactly do you mean by "broken ... ABS sensor?" Do you mean the wire is broken? If so, just splice them back together!
Thanks for your feedback. Putting everything back together after repairing front suspension, the mechanic accidentally broke the "L" shape end-part of the cable that goes into the hub, so have to replace whole cable. I told him to put it back in place until I could get back with the part to replace it. I got it, but hadn't been back to that mechanic.;-]#
Old Oct 11, 2019 | 07:26 PM
Originally Posted by MrHSE7
Regarding the spongey brake feeling after the booster and brake master cylinder were replaced. I would double check that the brakes were bleed properly. Any air in the system or lines can cause the spongey pedal feel. I recently did the same repair (booster & MC) to my D2 and bleed them manually twice but now have achieved great braking once again. It's a bit of work but well worth the effort.
With everything said prior I would fix or replace the bad ABS sensor, bleed the brakes, clear all codes and go from there.
Good Luck
Thanks for your response. Repair guy said he had bleed it twice, but will check again in a week or so, when I'll go back to check the codes again.
I skipped replacing the known faulty ABS sensor today, we just cleared the codes and will check again in a week or so. ;-]#
Old Oct 11, 2019 | 07:32 PM
Latest update! ...after clearing the codes, the Brake light and 3-Amigos were still lit. Drove from repair shop to office (3 blocks away) ...parked and went back to work. When I got off work and started the Disco, 3-Amigos were lit, but no Brake light at all. Weird since the first time it came on was after the ABS Sensor got broken, and never went off until today. Any ideas?
felipenaves
Sep 7, 2021 02:59 PM
coors
Apr 4, 2018 07:06 PM
mcaramb
Oct 9, 2017 11:57 AM
hossiena
Jul 18, 2013 10:48 PM
myquealer
Feb 11, 2012 03:56 PM
