AC clicking/buzz
Old Jun 11, 2019 | 02:42 PM
jastutte's Avatar
Default AC clicking/buzz
i know very little about the AC system.
on our last road trip the AC in one of our '04's starting blowing a little warm. so, we stopped and i picked up one of the $50.00 AC refill bottles with a gauge on it and checked the system. gauge read low so, i recharged until the bottle gauge gave me a good reading. after doing this the AC blew colder air and off we went. this lasted us a week and then i needed to do the whole process again using most of the rest of the first bottle of refrigerant that i had bought.
now the AC is still blowing cold air but there is clicking/buzzing sound coming from the engine bay. when this happens the AC pressure gauge that i have hooked up will shoot up to the over pressure range and then drop back down to normal pressure after the clicking/buzzing stops.
anyone have any experience with this?
Old Jun 11, 2019 | 06:07 PM
Red5's Avatar
Can you tell what is causing the clicking? Is the center of the compressor clutch spinning when you hear this noise?
Old Jun 11, 2019 | 06:24 PM
Best4x4's Avatar
Pressure drops when the AC clutch is engaged & rises when the AC clutch is disengaged.
Old Jun 11, 2019 | 06:55 PM
jastutte's Avatar
the AC is on and blowing cold air. my daughter is out with the truck right now so, that's the best i can do.
Old Jun 11, 2019 | 06:56 PM
jastutte's Avatar
so, that would seem to indicate the clutch is momentarily disengaging. why would it do that?
Old Jun 12, 2019 | 06:28 AM
zuke's Avatar
There is a low pressure switch that will cycle the compressor if your freon is too low. Also a high pressure switch if your pressure is too high. Also possible you have air in your system.
Old Jun 12, 2019 | 10:26 AM
JUKE179r's Avatar
I can easily see this happening when people use the DYI refrigerant-in-a-can wrong.
Old Jun 12, 2019 | 02:03 PM
jastutte's Avatar
thanks for the suggestions.
i'll check out what i can and check back in.
rovingaz Ryan
Sep 9, 2019 01:47 PM
Cjlr3
Aug 16, 2019 02:22 PM
PhilipC
Jul 22, 2018 06:23 PM
DieHard
Jul 14, 2017 09:19 AM
scottmb23
Aug 17, 2013 08:23 PM
