AC/Heat blowing smoke/fog into the cab. What do I do
Old 11-07-2010, 09:47 AM
bulldozer32's Avatar
alright thanks fellas. Ill report back in a few days when I take it in too see. Is it easy to tell if its cracked visually, or do I have to take it in and have the dealer do a diag test.
Old 11-07-2010, 09:53 AM
DarylJ's Avatar
Originally Posted by bulldozer32
I was driving around today and had the eat going. I quickly noticed smoke or something like smoke. Maybe fog or steam. I smelled weird though. I put the windows down and turned the ac off.
So was the heat on or the AC on? Or both (defrost)? You're saying the heat was on, and then saying you turned the AC off.
Does the AC still work? As in - blow cold? If not, did it work before?
Its odd the heat on the car is amazing. It gets so hot in the cab i usually have to turn it off and let it cool back down. Its two extremes. Either really hot or really cold. There is no middle.
Now I'm even more confused. Your sig says you have an 04. Are you not putting it on auto and setting a temperature? If not, why not?
Old 11-12-2010, 01:37 PM
the truck's at the shop and they are running a diagnostic plus the fuze to my horn blew (too much tooting i guess ) but anyways they think the ac plugs are clogged and they told me it would be about a half-hour labor cost to unclog them. Thanks for the help guys.
Old 11-12-2010, 02:14 PM
lipadj46's Avatar
Your horn is probably going bad. Also if you knew how easy it was to clean your AC drains you are going to feel like a fool for paying someone to do it (if you have ever seen a chimp use a stick to get termites it is the same concept).
Old 11-12-2010, 03:00 PM
D2's Avatar
D2
D2 is offline
X2 on the heater core
I had the same syptoms when my heater core developed a pin hole. You can bypass the core on the engine side of the firewall to get you home. ( or to get you home and then back and forth to work for a month.)
Have not had the drain plug issure so I can't comment on that. But way cheaper and easier to check/ fix I would imagine.
Off to check my drain hoses.
PLOWER99
01-10-2013 08:02 PM
Havoc556
11-01-2011 08:48 AM
JStephen
02-02-2010 06:59 PM
pressure_welder
11-21-2008 08:21 AM
boilerman
11-12-2008 07:35 AM
Quick Reply: AC/Heat blowing smoke/fog into the cab. What do I do
