AC Issue
Old Jun 14, 2015 | 10:08 PM
bostongrun's Avatar
Default AC Issue
I have 2002 Disco.
I thought I had a an a/c compressor issue but discovered that the compressor worked when I jumped the relay. The a/c works perfect 30/180 lbs and 47 degree F at the vents.
I replaced the relay but the system will not work unless I jump the relay.
No blown fuses or other issues
ntrol
I have automatic climate co
Any advice?
Thank you in advance
Old Jun 14, 2015 | 10:18 PM
disc oh no's Avatar
I would try checking the pressure sensor. If it's not working correctly, the a/c won't come on. Also, sometimes just adding a can of refrigerant will get it working again. Over time, the system will sometimes lose just enough to stop working.
Old Jun 15, 2015 | 05:52 AM
drowssap's Avatar
back pressure is to low, "i" think
Old Jun 15, 2015 | 02:58 PM
OffroadFrance's Avatar
The A/C system has a self diagnostic program, I can't recollect what you have to do exactly but check your owners handbook or the RAVE manual where it tells you the routine.
Alex_M
Nov 17, 2014 07:34 AM
nate2k5
Jun 3, 2012 05:49 AM
Kingmarine
Feb 26, 2012 09:27 PM
tunernewb92
Oct 20, 2009 07:15 PM
dms98e
May 9, 2008 08:36 AM
