AC Not as cold
Old Sep 19, 2017 | 11:56 AM
lndrover@carolina.rr.com's Avatar
Default AC Not as cold
I have a 2000 Disco II that I keep in mint condition. Just had the ac compressor replaced as the bearings in my original were giving out. Ive noticed that the system is not near as cold as it use to be. My mechanic has all levels of cooling fluid in the system right. I was just wondering if I may just need to replace the rest of the system condensing fan etc. from age. Everything else is original from when I bought It knew. Thanks for your thoughts.
Joseph
Old Sep 19, 2017 | 12:35 PM
No Doubt's Avatar
Don't most people also replace the drier when they do the compressor??
Also, check your engine coolant temp and fan blower condition.
Old Sep 19, 2017 | 01:27 PM
mln01's Avatar
What temps are you getting from the center-dash A/C outlets? I see by your email address you may be in or near Charlotte. My truck typically gets into the low 40s on a typical hot, humid Charlotte afternoon. It's not as cold as my Accord which gets to the low 30s but it does pretty well.
Old Sep 19, 2017 | 02:12 PM
Its only blowing like 52 degrees.
Old Sep 19, 2017 | 02:29 PM
04in719's Avatar
A couple ideas...
What about the aux electric fan in front of the condenser behind the plastic grill? Is it coming on when you switch on the A/C (and the ambient temp is around 85 degrees I believe and engine is to operating temp.)??
That aux fan helps keep the head temperature (condenser) down which will in turn allow the evaporator (inside the truck) to pull more heat of the the air (blow colder air).
I would hope the mechanic charging the system would check for that.
Possibly the "blend door" is letting some hot or outside air mix in?
Does the compressor click on and off real quick while it's blowing the not so cool air? Could be too much pressure in system when hot (see head temp above).
Old Sep 19, 2017 | 02:47 PM
You could be right. I have been thinking the recirculate or whatever the shut of for the outside air is called might not be working. Im going to take it back in and have all of those things checked. I know the compressor is turning on and off every like 2 seconds when the engine is just idling. Thanks for all the info.
Old Sep 19, 2017 | 03:03 PM
Red5's Avatar
That sounds like you need more Freon. You need a set of gauges to confirm though.
Old Sep 19, 2017 | 03:08 PM
04in719's Avatar
The compressor cycling so much at idle doesn't sound right.
Too high of pressure or like Red5 said a refrigerant too low problem. But in my experience the latter would keep the compressor on for extended periods of time trying to build up the pressure.
Keep us posted for posterity.
Old Sep 20, 2017 | 11:26 AM
abran's Avatar
They are right, a cycling compressor means the freon level is incorrect. The garage needs to fix that on their dime.
mattmo78
Nov 21, 2013 01:23 PM
pkppunk
Jan 26, 2013 07:05 PM
eddyendo
Jun 1, 2008 04:41 PM
wease206
Jul 27, 2007 12:23 PM
baby0411
Jan 30, 2007 10:42 AM
