acceleration problem Disco2 at 2500rpm
Old Feb 18, 2009 | 03:35 AM
ctjawadisco2's Avatar
7th Gear
Default acceleration problem Disco2 at 2500rpm
Hello friends, my Disco 2 from 1999 TD5 has problems when accelerating at 2500 to 3000 rpm . Is that a known problem? It seems as if the gas or fuel will partielly be cut off at accelerating? what could this be? I just cleaned all parts of the incoming air, changed air filter, fuel filter, even the very expensive fuel pressure valve at the rear part of the cyl head!! no better result. Is there anybody that has an idea what it could be? Thanks Tobias
Old Feb 18, 2009 | 08:58 AM
Wish I had a diesel so I could answer that question.
Old Feb 18, 2009 | 07:17 PM
Well, diesels have all of their power at low RPM not high RPM, so what you are feeling is the lose of power because you are well beyond the power band.
Why are you revving the engine that high anyway?
I have a V8 and I never go higher that 3,000 rpm, and that is only if I need to merge with traffic on the expessway.
How long have you owned the truck?
Old Feb 18, 2009 | 08:45 PM
unimoged's Avatar
Does it have an automatic or a manual transmission.
Check your intake ducts for cracks or loose clamps from the turbo to the manifold.
Old Feb 19, 2009 | 02:37 AM
7th Gear
Its manual.
Old Feb 19, 2009 | 02:39 AM
7th Gear
Thanks spike555, but the best power performance of this 2,5l Diesel is at 3000rpm and it is not comparable with the high volume V8. Thanks for your help.
Waltmink1
May 3, 2025 01:11 AM
AustinMiniMan
Sep 2, 2010 04:55 PM
cnissen73
Aug 6, 2009 09:15 PM
kinsella
Apr 21, 2007 10:21 AM
oldrangerover
Jul 18, 2005 03:20 PM
