ACE error
Old Dec 22, 2022 | 03:11 PM
saint's Avatar
4th Gear
Default ACE error
Hi Im new here , please throw me a line on this if you can. My 2000 disco v8 has an ACE problem scanner says the latest page of data was corrupt at last power up and pressure signal stuck at a value. System pressure 129.23 bar . If anyone cares to comment I would appreciate.
Old Dec 23, 2022 | 12:02 AM
longtallsally's Avatar
Have you done a service on the system? Flush, filter change…. Also, what are you using to capture data? A Nanocom is invaluable in getting ACE codes and such.
Old Dec 23, 2022 | 07:34 AM
saint's Avatar
4th Gear
Default ACE error
Thanks for your prompt reply . I have a hawkeye scanner. I haven't t service it what concerned me is this business of "the latest page of data was corrupt..." from info I gathered it seems it could be electrical or the BCU itself may ne to be reprogrammed so I don't know how to go about it.
Old Dec 23, 2022 | 07:36 PM
H Hill's Avatar
Search this forum for ACE fluid change. Do the process and see if it improves the situation. I use a Nanocom so I have no experience with the Hawkeye
Old Dec 23, 2022 | 08:29 PM
saint's Avatar
4th Gear
Thank you! I will.
Old Dec 26, 2022 | 04:16 AM
cmansilla's Avatar
Do you have fault codes? Maybe the problem is the pressure transducer
Old Dec 26, 2022 | 09:15 AM
saint's Avatar
4th Gear
Yes it reads latest page of data was corrupt at last power up
markdeg
Mar 28, 2018 09:05 AM
p.nieuwenhuis
Jun 11, 2012 08:44 AM
Joshman
Mar 27, 2012 12:01 PM
jycsalas
Dec 17, 2008 11:00 AM
alrd
Nov 17, 2006 11:25 AM
