Ace Hydraulic Line Repair or Replacement?
Old Oct 2, 2020 | 04:25 PM
RoverLar's Avatar
4th Gear
Default Ace Hydraulic Line Repair or Replacement?
So the short story is this, I finally got under my LR today to diagnose why the ACE light was on. Looks like the sway bar end link sheared off of the ACE system which allowed the hydraulic lines to get low enough to where one of the lines rubbed on the driveshaft enough to where it wore a hole and is now leaking fluid. Replacing the sway bar endlink is easy enough, but.
Is this something that could be cleaned up and repaired? Or do I need to replace the line all together?
If it needs replacing, anyone know where to find one?
Thanks in advance!
Broken endlink
Rubbed hole
Old Oct 2, 2020 | 05:29 PM
Best4x4's Avatar
Any decent shop that messes with high pressure lines should be able to make you a replacement hose. Or check with Rovers North or Atlantic British.
tobinmakayla@gmail.com
May 14, 2020 02:57 AM
jclrd01
Jan 31, 2014 01:46 PM
captain203
Dec 18, 2013 06:41 AM
greenwade
Apr 13, 2010 10:08 PM
TraV300
Dec 9, 2008 09:17 AM
