ACE system line
Old Dec 15, 2013 | 09:23 PM
captain203's Avatar
Default ACE system line
hi has anyone repaired one of the steel lines for the ACE system? without replacing the line?
Old Dec 16, 2013 | 08:44 AM
dusty1's Avatar
educational ace reading ACE - Active Cornering Enhancement
and it looks like a patch will be a weak link. I'd go for full replace of line
Old Dec 17, 2013 | 08:30 AM
drowssap's Avatar
as you said it is just steel tubing, try replacing it with steel fuel line and compression fittings you really have nothing to lose.
if you are looking to replace it try some of the English sites someone over there makes replacement tubing in sections.
I "believe" LR is one big piece of tubing.
Old Dec 17, 2013 | 06:11 PM
captain203's Avatar
I spliced in a section of Steel line with compression fittings so far so good.
Old Dec 17, 2013 | 07:34 PM
Dane!'s Avatar
I had to replace a line also, Land Rover only sells half lines, I used a high pressure coupling and its still holding. I recommend you get some vacuum line, I'm not sure the diameter of the ACE lines, but wrap the vacuum line around the ACE line, it protects it from salted roads and stray rocks shot at them.
Old Dec 17, 2013 | 07:39 PM
dusty1's Avatar
Sorry, What do you mean by vac line, that rubber stuff? Like shrink stuff? Or just a length of vac hose slid over it?
Old Dec 17, 2013 | 08:43 PM
Dane!'s Avatar
I used the vacuum line from AutoZone, rubber kind used on your brake booster, cut it down the middle (like a hotdog(only example I could think of) and wrap it around the high pressure lines. I used an industrial type tape I found in my dads shop, wrapped it around the lines. The ACE system is a littler quieter when in use, but the protection the rubber line offered was good for my use, I live in the desert and a lot of gravel gets shot up under my truck.
Old Dec 17, 2013 | 08:45 PM
captain203's Avatar
The lines are 3/8
Old Dec 17, 2013 | 08:53 PM
Dane!'s Avatar
Then use a 3/8 Inner Diameter line and wrap it, the angles you'll have to use a thicker, because the line when cut wants to open more and wont want to fit, that's only if you'd like to do that job that is. Its was a pain in some of the cramped spots, removing the viscous fan will be needed, and I don't have the SAI pump so I'm not sure if that would be in the way either.
Old Dec 18, 2013 | 06:41 AM
drowssap's Avatar
doesn't matter most line rough from the inside out, anyway.
Tin_Man
Apr 12, 2014 11:12 AM
jclrd01
Jan 31, 2014 01:46 PM
thehrdway
Apr 26, 2011 01:41 PM
tbuckt007
Apr 13, 2010 11:46 AM
alrd
Nov 17, 2006 11:25 AM
