Advanced engine tune troubleshooting thread
Old Jul 13, 2015 | 12:52 AM
Charlie_V's Avatar
It could also be the MAF. I was having crazy problems exactly as you describe and my rover was gimped for WEEKS while I changed this and that. DiscoMike said swap the MAF and when I did it all went away. I'd changed so many things it could have been a combination.
I was lucky enough to hav a buddy who has the same rover and let me borrow his MAF.
Old Jul 16, 2015 | 04:42 PM
Extinct's Avatar
Never thought of the MAF, I wonder why it would miss on Cylinder #7 and only on startup with a bad MAF?
disc oh no - plug wires are new - I changed the new ones that were on the truck to new ones I had already just to double check, no change.
Hmmm, could be that dreaded end cylinder head gasket leak - leaking cold, not leaking hot and expanded - most likely answer I have heard so far (unfortunately). I wonder if a pressure test would find it?
RE: ECM rich lean cycle - I'm sure you already know this but for the benefit of our other readers - the ECM treats the O2 like a hi/lo switch - increases fueling of the injectors till it sees high, then decreases till it sees low - alternates between the two ditches so that average is in the middle - you can see it if you have a scanner with o2 voltage readout. BTW, almost all ECM's work that way - at least most of the one I have worked on/tuned which has been several.
Old Jul 17, 2015 | 05:04 AM
disc oh no's Avatar
Yes, the ECM takes the input from the o2 sensors and uses the readings to determine fuel injector pulse width. I was just saying that the millivolt readings that you see are produced by the sensors themselves.
As far as a gasket leaking into a cylinder, I've seen head and intake manifold gaskets do the same thing. I'm not sure if they actually stop leaking when the engine warms up??? They might, or if the leak is very small, it may take hours to build up enough coolant to cause a miss. So it could be leaking all the time, but maybe it's only noticeable during first start up.
I've had a customer car where it leaked enough overnight to noticeably slow the starter when I started it to bring it into the shop. That's scary! Fortunately, the crank didn't get damaged.
jhill15
Feb 12, 2013 07:12 PM
2fasttc
Jan 1, 2012 04:19 PM
booper169
Nov 7, 2010 10:27 AM
Garrett
Oct 22, 2010 10:11 AM
lipadj46
Oct 27, 2009 04:54 PM
