Advice on which engine is better?
Old Jun 30, 2009 | 11:39 PM
larson3000's Avatar
Default Advice on which engine is better?
Hi all,
I am new to the forum and Land Rover generally. I have been interested in Rovers for a while and am looking to purchase a gently used Rover Discovery. I have recently moved to Alaska. I will not be using the Rover for daily commuting. It will be a free-time/weekend vehicle.
Could I get some opinions on engines? Should I look for a 2003 or 2004 Discovery with the 4.6L? What are the pros and cons of the up to 2002 4.0L?
I look forward to hearing from you!
Old Jul 1, 2009 | 12:23 AM
Disco Fuego's Avatar
Hi,
Not an expert opinion, but I have both. The 4.6L has noticably more power than the 4.0L. There are some oil pump issues with some of the 2003, Do a search for the VIN#'s. Aside from the above there are not many differences. If I would be in the market, I would buy a 2004 4.6L right now. Although, someday I will get my hands on a 2004 Diesel (TD5)!
Hope this helps a little...
Old Jul 1, 2009 | 04:14 PM
They are the exact same engine, the 4.0 & 4.6, but the 4.6 has more horse power, you7 go from 200 to 216.
The 2004 is by far the superior truck of the 3 you are looking at.
https://landroverforums.com/forum/sh...ad.php?t=21328
Old Jul 1, 2009 | 05:43 PM
devildog01's Avatar
Default 4.6
Hey spike I can get a good deal on an 04 motor 54000k it was in a rollover.First ? is is it an easy swap and for $1500 bucks is it a good deal when my 01 disco has 160000k on it?
Old Jul 1, 2009 | 06:21 PM
That is a hell of a deal. Have you seen it yet, check and find out what comes with it.
Old Jul 1, 2009 | 08:13 PM
I agree with Mike, what you will need for the swap are the engine and the ECU for the 4.6.
Old Jul 1, 2009 | 08:24 PM
If you can't get the ECU, don't sweat it, the 4.0 ECU handles the 4.6 well.
aarongregor
Nov 14, 2011 08:31 PM
booper169
Oct 31, 2010 06:10 PM
mlfore
Apr 8, 2008 03:38 PM
tsuami1
Feb 21, 2008 03:58 PM
DV57
Aug 24, 2007 07:46 PM
