Advice - intake and heads or.....
Old Jan 5, 2011 | 12:09 AM
aschilp's Avatar
7th Gear
Default Advice - intake and heads or.....
I had my disco in the shop today and I was told I need to have the intake manifold gasket replaced. Any thoughts on having the mechanic take the next step and replace the head gaskets too?
I was told about $1300 for intake and $3000 for going all the way
2004 Discovery II
71K Miles
Old Jan 5, 2011 | 03:37 AM
kcabpilot's Avatar
I'm in the process of doing mine right now. It seems to me that it would be a false economy to pull the heads off and not do the valves, at least in my case where I have 100k miles. I can see that the valve and seat faces are showing some pitting and it's time for them to be refaced. Also, when into it this far do you want to put it all back together with the original water pump, thermostat, old coolant hoses and serpentine belt?
I'm even thinking new coil packs and ignition leads since they are so hard to get too.
My point is, that as you get deeper into it there's a level that you need to commit to. In your case, if the head gaskets aren't leaking you're probably best to leave well enough alone unless you want to go all the way.
Old Jan 5, 2011 | 09:06 AM
First, your mechanic is charging you double the price for either service. Labor on the intake is only around 4.5 hours, 11 for head gaskets, he is a thief.
As for your question, at your mileage I would do both and pay only $1500 to $1600 for the complete job plus new 8 mm plug wires.
Old Jan 5, 2011 | 09:50 PM
FightOnUSC79's Avatar
What mike said: I had the works done for 1590.00 I'll get the receipt and post the entire service that was completed if you'd like. Also, they washed the truck and put my preset stations back
Edit: Also included was a 1000 mile check up to make sure everything was tight and running properly
Old Jan 28, 2011 | 03:10 PM
aschilp's Avatar
7th Gear
Thanks for the replies and suggestions. I called around and found the cost comprable to what I was quoted. One was $300 cheaper for the intake manifold gasket, so took it there for a 2nd opinion. I trust them more and they ended up telling me I didn't have a leak in the first place! They repaired something else that I know needed fixed........
Old Jan 28, 2011 | 03:52 PM
bosshogt's Avatar
We are all curious. What did your 2nd more trusted shop repair?
Old Jan 28, 2011 | 06:17 PM
coors's Avatar
Yeah! You can't give a build up like this and not deliver. that's wrong. What did you "think" was wrong in the first place?
Shryan
Apr 1, 2013 08:53 PM
lipadj46
Jan 30, 2011 04:48 PM
tweakrover
Jul 3, 2009 04:37 PM
JBEGIN
Jun 27, 2009 12:38 PM
jkid
Oct 22, 2008 10:14 PM
