Advice / power steering issues amongst…
Old Jan 22, 2026 | 06:52 PM
Extinct's Avatar
Yep, should be fine
Old Jan 22, 2026 | 06:57 PM
Garrett Larrow's Avatar
Originally Posted by Extinct
Yep, should be fine
thanks ! Just towed it to be safe. Hopefully it’s just pump. I don’t see how gear box would go at the same time. Makes zero sense.
thanks for help. While I have you .
i have the non ace system. Read 50 articles of people saying dex 3 but then if jt gets cold may gum up. So regular is fine. Get synthetic. Don’t get synthetic.
so would this be ok? Mixed blend synthetic dex 3
https://a.co/d/49fYyUz
also i couldn’t find on boards or rave. What is the capacity of the power steering system when flushing etc?
thanks
Old Jan 22, 2026 | 08:36 PM
Windycity_rover's Avatar
I ran Valvoline Maxlife ATF for years. No issues. Alternative to ATF - Pentosin CHF 11. Chicago Rover in artic temps! -40 forecasted for Friday....never gummed up.
Old Jan 22, 2026 | 09:49 PM
thanks. did you run the max life stop leak version or just regular no stop leak?
Old Jan 22, 2026 | 11:46 PM
Regular......Check out Atlantic British "How To" section for power steering pump video. It will give you plenty of insight.
Old Jan 23, 2026 | 07:55 AM
huggi's Avatar
Installed this pump a few months ago - seems to be working fine
Amazon Amazon
WarrenZ
Jan 9, 2024 07:53 PM
johnkbl
Sep 21, 2023 06:17 AM
Broken08
Mar 13, 2023 06:34 PM
cybercop
Feb 3, 2022 12:10 AM
Pacerlive
Aug 22, 2013 07:41 PM
