After Head Gasket now no fuel
Old Aug 21, 2010 | 10:53 AM
dave41's Avatar
Default After Head Gasket now no fuel
I have completed a head gasket job on my 03 disco with 116,000 got it back together and hooked up the battery. Went to start it and the flashers will not shut off and the truck will not start. Does the fuel rail need to be primed? The plugs are dry after about a total of 3 min cranking not all at once. I have a charge on it for now and will try again in a hr. or so.
Old Aug 21, 2010 | 10:57 AM
Bundu's Avatar
Banned
Did you replace the fuel pump relay if you removed it?
Is the gas line connected to the fuel rail, it may have popped off.
Press the schrader valve at the left back of the fuel rail and see if you have fuel pressure.
Old Aug 21, 2010 | 03:44 PM
lordmorpheus's Avatar
Press the immobiliser button on the right side of the firewall. With the flashers on, and engine no start, that would be where I'd start. On the passenger (right) side of the firewall, there is a black plastic button with a rubber button cover. Press the rubber button to reset it. It's there in case of an accident to shut off your fuel pump.
Old Aug 23, 2010 | 08:41 AM
dave41's Avatar
Lordmorpheus you are correct it fixed the problem Thank You!!
ctk111
Nov 20, 2012 02:23 PM
davidlafrance
Mar 10, 2011 03:40 PM
audioclay
Nov 12, 2009 09:17 AM
dontknow
Aug 25, 2008 09:20 PM
