Aftermarket D2 rims?
Just bought myself an 03 Disco 2 about 2 months ago and I've been doing all the research I can but I just CANNOT find any aftermarket rims that will fit the truck. Do companies just not support the 5x120 bolt pattern for off road rims? The only set I've found was a set of 16 inch steelies, which I have no problem with except mine came with the 18 inch rims, so I'd prefer to stay with that rim size. Any help would be appreciated!
I have found plenty of aftermarket wheels in 16 & up sizes. The issue is with the offset. They’ll end up sticking out nearly 2inches on most of them & not only does it look crappy but it will cause the tire to wanna eat the rocker guard when turning. It also places more stress on the hub assembly as the wheel isn’t as centered on the hub vs the OEM setup.
carid
Appearance & Camping Set Ups
12-12-2014 07:56 AM
