Aftermarket D2 rims?
Old Oct 9, 2018 | 10:12 AM
x2c.diamundz's Avatar
4wd High
Default Aftermarket D2 rims?
Just bought myself an 03 Disco 2 about 2 months ago and I've been doing all the research I can but I just CANNOT find any aftermarket rims that will fit the truck. Do companies just not support the 5x120 bolt pattern for off road rims? The only set I've found was a set of 16 inch steelies, which I have no problem with except mine came with the 18 inch rims, so I'd prefer to stay with that rim size. Any help would be appreciated!
Old Oct 9, 2018 | 10:20 AM
Richard Gallant's Avatar
Good luck it is a hard bolt pattern to find.
Old Oct 9, 2018 | 11:52 AM
Best4x4's Avatar
I have found plenty of aftermarket wheels in 16 & up sizes. The issue is with the offset. They’ll end up sticking out nearly 2inches on most of them & not only does it look crappy but it will cause the tire to wanna eat the rocker guard when turning. It also places more stress on the hub assembly as the wheel isn’t as centered on the hub vs the OEM setup.
Old Oct 10, 2018 | 02:32 AM
JUKE179r's Avatar
The bolt pattern on a Disco 2 is a 5x120mm just like some BMW rims.
Old Oct 10, 2018 | 06:15 AM
redwhitekat's Avatar
plus the oem rims look very fine
carid
Appearance & Camping Set Ups
Dec 12, 2014 07:56 AM
disco360
Mar 8, 2013 10:08 AM
billymoto25
Nov 10, 2010 08:09 AM
03discoman
May 7, 2010 12:32 PM
Harvard
Apr 30, 2008 04:58 PM
