Aftermarket radio wont install all the way in dash
Old Aug 25, 2018 | 07:57 AM
04in719's Avatar
Default Aftermarket radio wont install all the way in dash
I just bought an aftermarket 7" LCD single DIN head unit. The screen slides out and up.
Install was fairly easy as I already had an older Kenwood unit in with the harness adapter (it's much shorter).
Problem I'm having is the unit won't push all the way into the dash. I've got the wires, harness, antenna all neat but fear it's the bracket way back in the dash that's keeping it from going the extra half inch or so needed to mount flush into the dash.
Any thoughts? The bracket looks pretty stout to try to bend or cut.
Thanks all.
Old Aug 25, 2018 | 08:03 AM
Kdo58's Avatar
I had the same problem, can’t remember what I actually did to fix it, seams like i removed the stud on the back of the radio to make it go all the way in.
Old Aug 25, 2018 | 08:45 AM
04in719's Avatar
The factory radio has the stud in it that seems like it lines up with the bracket back in the dash.
My issue (I think) is that bracket is keeping me from getting the new head unit to push in all the way.
I guess my basic original question would be if that bracket can be removed or bent to make room.
Old Aug 25, 2018 | 09:13 AM
Kdo58's Avatar
This is how mine turned out
Old Aug 25, 2018 | 10:42 AM
Kdo58's Avatar
You can buy a filler piece for the bottom, I did not bother, you need to use the rubber piece from the stock stereo and put it on your new stereo, keeps it from moving around, and lines every thing up.
Llamasayswhat
Dec 9, 2018 11:05 AM
ReconDoc83
Sep 16, 2018 11:38 PM
UselessDisco
Nov 24, 2009 08:45 PM
courtslu
Jan 14, 2009 05:44 PM
zracin
Feb 18, 2008 09:56 AM
