Air Compressor wont turn off
Old Apr 29, 2021 | 09:24 PM
4RoverLane's Avatar
3rd Gear
Default Same issue air compressor won't turn off. What was the solu
Sorry, I was just talking to my husband who said I needed to clarify , we know there is a leak from the previous owner, however, this time the air compressor does not turn off when the vehicle is turned off and continues to run. This is a new issue. Normally when the car turns off the, the air compressor also turns off.
I had to disconnect the battery while I was at work and then again when I got home in order to stop it from running.
Suggestions?
Thank for any guidance.
Old Apr 29, 2021 | 10:15 PM
mollusc's Avatar
Probably the leak has gotten to the point where the compressor can't keep up with it. Pull relay #5 (as I said) to cut power to the compressor. And fix the leak.
Old Apr 29, 2021 | 10:53 PM
Harvlr's Avatar
Or the relay has failed closed. Replacing the relay might solve the problem. If there is a leak it should still be fixed.
Old Apr 30, 2021 | 08:26 AM
4RoverLane's Avatar
3rd Gear
Default Thank you!
Thank you for the information. We will check out relay and fix the leak. We will give an update on progress.
05TurboS2K
Aug 7, 2019 07:47 PM
cptshanman
Sep 4, 2012 02:19 PM
CANAMDiscovery
May 4, 2012 09:47 PM
GCS1
Feb 17, 2008 07:30 PM
DiscoDave
May 3, 2007 07:01 PM
