aircon noise
Old Jul 18, 2007 | 02:16 AM
suveer's Avatar
Default aircon noise
Hi All
When i swithcj on my aircon, there is a shrill sreeching noise on start up. Sound like from the compressor.After a few minutes it stops.Can anyone help as to what this is. Does the compressor need a service?
Thanks guys
Old Jul 18, 2007 | 07:33 AM
Default RE: aircon noise
How many miles on your truck, what year is it, how long since you changed out your serpentine belt?????
Mike
Old Jul 18, 2007 | 07:47 AM
suveer's Avatar
Hi Mike
My disco is 1997, 300tdi. It has 230 000km and a new serpentine belt.
Thx
Old Jul 18, 2007 | 08:44 AM
How about the belt tensioner, it may be getting weak and not keep the proper belt tension?
Mike
Old Jul 18, 2007 | 12:07 PM
breal372002's Avatar
Check the compressor clutch to see if the bearing is seized or not seated properly. Also see if the compressor is energized.Check compressor and air gap.
Old Jul 19, 2007 | 12:08 AM
suveer's Avatar
Hi Guys
Mike - Where is the belt tensioner? Also the noise is only on start up of the aircon, for about 5 seconds.
Also how do you check the compressor clutch and bearing ?What do you mean by energised?
Forgive me guys, i am really not a mechanically minded person. i therefore look for support from you helpful people.
many thanks
Suveer
Old Jul 19, 2007 | 01:51 PM
98roverguy's Avatar
Belt tensioner is going to look like this. Over time it loses its ability to keep the belt nice and tight, which cause squeels.
http://www.roverparts.com/Parts/ERR3440.cfm
Old Jul 23, 2007 | 02:14 AM
johnnybob06's Avatar
How long do belt tensioners usually last?
I've got a squeel, but.. not really...
let me explain..
If I have the AC turned off, it normally revs around 600-700 rpms... sounds amazing...
when I turn on the a/c OR rev to around 850ish-900 rpms I get a squeel!
Over or below that area, there is no noise... but once I turn the a/c on, or rev up there.. there goes the noise!..
what is it?!
Are belt tensioners easy to replace? first off... is it my belt tensioners?
Thanks in advance!!!
John-Robert
Old Aug 18, 2007 | 11:18 AM
lebrult's Avatar
I have the same issue on startup with my 2003 disco II. squeel for 5-10 sec on startup. I will do some research and post a follow-up. Anyone out there with some info??
pompepe
LR4
Mar 5, 2013 03:33 PM
TbwCurtis
Jan 13, 2011 09:48 AM
redmanc
Dec 26, 2008 09:13 PM
yuenie
Aug 15, 2008 07:02 PM
norcalfrank
Aug 10, 2007 01:33 PM
