All D2 Dashes the same?
The LR kit (which is now I think made by Britpart) is a good fix for the peeling up between dash and windshield area. It seems like installing it when the windshield is out of the car would yield better results than trying to use an offset screwdriver with the windshield in. BTW.
However, the only fix I've seen on this front part above the radio peeling up ASIDE from swapping dashboards that ... may work ... is inject glue (something very strong, like military watercraft adhesive) under the front where it's peeling up (above the radio), then placing heavy (multiple 10 pound ?) diving weights (metal / or coated) on it to weigh it down for a few days. Using a syringe etc. Might work? Might not? Not injecting glue thru the dash, but between the dash and the part that is peeling up.
Well, after a few hours at my local pick n pull I now have a non-warped dash. It isn't black, but that can be easily changed. Taking it out wasn't hard, just tedious. The hardest part on the removal of a dash from a vehicle you don't want to damage is unclipping all of the wiring. The only casualty during the removal was one bloody knuckle and the mount that holds part of the dash facia to the dash itself. The metal bracket is only rivetted onto the plastic dash and not by very big rivets. This will be easily fixed with a thin metal backing plate and re-riveted.
whowa004 (04-28-2022)
NewToTheTwo
10-12-2019 07:57 PM
Steve Selyutin
08-26-2019 12:46 AM
