All D2 Dashes the same?
Old Apr 27, 2022 | 06:53 PM
nashvegas's Avatar
The LR kit (which is now I think made by Britpart) is a good fix for the peeling up between dash and windshield area. It seems like installing it when the windshield is out of the car would yield better results than trying to use an offset screwdriver with the windshield in. BTW.
However, the only fix I've seen on this front part above the radio peeling up ASIDE from swapping dashboards that ... may work ... is inject glue (something very strong, like military watercraft adhesive) under the front where it's peeling up (above the radio), then placing heavy (multiple 10 pound ?) diving weights (metal / or coated) on it to weigh it down for a few days. Using a syringe etc. Might work? Might not? Not injecting glue thru the dash, but between the dash and the part that is peeling up.
Old Apr 27, 2022 | 08:20 PM
matt3502's Avatar
Roger That.
Do you think it was design flaws like this that caused the downfall of the British Empire?
Old Apr 27, 2022 | 08:28 PM
gecko951's Avatar
WTF, I thought these dashes were generally long-lasting but maybe this can happen in a humid environment? Does it mostly affect black dashes?
Old Apr 27, 2022 | 09:14 PM
Alex_M's Avatar
Humidity is definitely a contributing factor. My buddies d2 did this immediately after filling the truck with water (sunk up in a mud hole).
Old Apr 28, 2022 | 06:38 PM
MSGGrunt's Avatar
Well, after a few hours at my local pick n pull I now have a non-warped dash. It isn't black, but that can be easily changed. Taking it out wasn't hard, just tedious. The hardest part on the removal of a dash from a vehicle you don't want to damage is unclipping all of the wiring. The only casualty during the removal was one bloody knuckle and the mount that holds part of the dash facia to the dash itself. The metal bracket is only rivetted onto the plastic dash and not by very big rivets. This will be easily fixed with a thin metal backing plate and re-riveted.
Old Apr 28, 2022 | 09:50 PM
Frank4's Avatar
Well done, sir.
Old Apr 30, 2022 | 08:14 AM
mln01's Avatar
Those seat cushions look pretty good. If I were near where you are I'd go grab them to tuck away for when the ones in my truck need to be replaced. Again.
Old May 1, 2022 | 02:07 PM
nashvegas's Avatar
I did the same - pulled a spare tan (perfect condition, not even any cracks up on the black plastic by the defroster,...) dash on an afternoon -- just so I have it.
wrightb8289
Jun 15, 2021 03:10 PM
NewToTheTwo
Oct 12, 2019 07:57 PM
Steve Selyutin
Aug 26, 2019 12:46 AM
09dewaed
Dec 28, 2017 10:20 PM
jbarr89
Jun 21, 2016 12:43 PM
