all of my frustration
Old Jul 12, 2013 | 10:23 PM
FlyingZebra34's Avatar
Ok so the coolant isn't coming from the head gaskets/elbow or valley pan. Is it lightly coming down from that small port on the bottom of the bell housing. Any ideas?
Old Jul 13, 2013 | 12:34 AM
Ok well turned it on and I'm loosing coolant everywhere. Lots of steam from the passenger exhaust. So burnt out on this truck right now.
Old Jul 13, 2013 | 06:14 AM
jfall's Avatar
Remove the intake and try to torque all the intake bolts properly. You probably missed a few of them.
Did you get the two coolant hoses on to the plenum heater element? Those are not pissing out on top of the engine some where unattached?
Radiator shroud bolts not leaking from cracked radiator plastic?
Any of this stuff can leak and pool up elsewhere.
Our you spilled - filling it all up.
Old Jul 14, 2013 | 05:28 PM
Retorqued Inlet manifold, everything is dry. Hoses under pelum aren't leaking either. Any other reason I would get white smoke from passenger side exhaust? Or coolant from that small port on the bell housing
Old Jul 14, 2013 | 05:36 PM
Still getting the white smoke and the leak? Coolant could enter cylinder from head gaskets; and intake valve from intake manifold (would be difficult).
Old Jul 14, 2013 | 05:37 PM
How likely is it that head gaskets would instantly fail?
Old Jul 14, 2013 | 08:24 PM
caymandrew's Avatar
Nothings sucks more than having to do it twice however, I've come to realize this is written in stone as per the Rover Gods... If I had a dollar for every Rover project I had to do twice... Sucks bad man but you have to stay positive and just knock it out. Once you're done with the head gaskets, you're going to feel great knowing you have nothing major to worry about for a while..
Old Jul 14, 2013 | 08:59 PM
Failure to have heads skimmed flat by machine shop
Torque failed because you missed a bolt or a step
Stripped bolt, folded over gasket (hard to do), metal scrap between gasket and block, re-used old bolts.
Old Jul 15, 2013 | 01:32 AM
I didn't machine the heads seeing as how I never over heated and it was in tolerance. I marked the bolts and turned them in the right sequence. After re-torquing the inlet manifold I stopped the steam out of the exhaust but it looks like I'm loosing coolant out of the back of the head gasket on the passenger side so I guess I'll be buying all new gaskets and bolts again
Old Jul 15, 2013 | 01:58 AM
I love this thing so much but I can't wait to get it running again.
