ALRM/STEERING/KEY LOCK DOWN MODE
Old Jul 31, 2008 | 10:37 AM
SPENCEC75's Avatar
Default ALRM/STEERING/KEY LOCK DOWN MODE
Wife's 2000 disco II is stuck at BabiesRUS. The steering wheel is locked and key will not turn. Tried resetting alarm with 3 locks/unlocks. Pulled battery. Hit ignition with Hammer(PLUS LUBRICANT). Checked Fuses. Any ideas? I saw something about the spider problem, but don't know if that relates to this. I have done many searches, but have come up empty. PLEASE HELP!
Old Jul 31, 2008 | 10:41 AM
Default RE: ALRM/STEERING/KEY LOCK DOWN MODE
Has she parked up against a parking stop? Trying turning the wheel hard when turning the key.
Old Jul 31, 2008 | 10:54 AM
SPENCEC75's Avatar
THANKS FOR YOUR REPLY! We have pulled on the wheel and turned the key. I also have rocked the car back and forth. It is not on a parking block. Any other ideas? Thanks,
Old Jul 31, 2008 | 02:22 PM
Switzer's Avatar
You could try putting the T-case in neutral and rolling the car back and forth. Of course you should only try this on level ground.
Cheers,
Pete
Old Jul 31, 2008 | 07:38 PM
Rock the steering wheel back and forth as you turn the key.. I am assuming that the wheel is cranked hard to one side, never do this when you park, always straighten the wheels or you can lock your steering wheel.
Old Dec 16, 2010 | 03:32 PM
awenzel85's Avatar
(2004 Disco II HSE) I just went through this. I used Graphite Powder Lubricant, and hit the ignition with a hammer and also tapped the key gently with the hammer. It worked and the car started immediately. However, the radio doesn't work, the key fob won't lock or unlock the doors and the clock has been disabled but I can drive the car....Any suggestions?
angasreid
Dec 16, 2023 07:45 AM
Newfoundlandrover
Oct 2, 2011 06:51 PM
cmossman
Jul 19, 2010 03:06 PM
plastique999
Jan 22, 2008 01:34 AM
yarddawg
Dec 10, 2007 05:19 PM
