Alternator issues or?
Old Mar 3, 2018 | 09:11 AM
shanechevelle's Avatar
I used to have a battery with a bad cell. I would carry water with me, fill the cell, start the car. Once the water was gone it didn't have enough juice. Add some water....start right up lol.
Attach your meter to the battery before you crank, then watch it WHILE you crank, if the voltage drops too much your battery is on its way out. A battery can have 12 volts and still be bad.
Old Mar 3, 2018 | 12:48 PM
Disco Tez's Avatar
Thanks Sir! Now let’s Rover on!
Old Apr 14, 2018 | 08:33 AM
JUKE179r's Avatar
Originally Posted by Best4x4
... you can grab a 99-02 Range Rover 150AMP unit that will be 100% PNP.
Should it be required to change to a higher amperage fuse link (FL1 is already 150Amp) if you swap from the 130Amp to the 150Amp alternator?
Old Apr 14, 2018 | 01:22 PM
Best4x4's Avatar
I stuck with the 150AMP fuse and I've ran that setup for years with zero issues, but I think you can get a 175AMP Mega fuse from Oreilly's. I know they sell 200AMP ones, but I think it's 125, 150, 175, 200 if I'm not mistaken.
Old Apr 14, 2018 | 08:10 PM
JUKE179r's Avatar
Thanks for that info Best4x4.
Old Apr 14, 2018 | 08:34 PM
Best4x4's Avatar
No problem at all!
matrixclese
May 30, 2010 03:09 PM
diverdad69
Apr 23, 2010 08:50 AM
JumPeR04
Dec 17, 2009 07:57 PM
mgabriel
Dec 11, 2008 11:53 PM
ehuppert
Feb 9, 2008 06:41 PM
