Am I going to break anything by doing this?
Old Aug 26, 2020 | 04:00 PM
Brandon318's Avatar
Default Am I going to break anything by doing this?
Taking off the axle nut. Three wheels on the ground. CDL engaged. Transmission in park. Am I going to harm anything in the diff or axle by bearing down on this?
In hind-sight I should’ve loosened it with the brakes applied.
Old Aug 26, 2020 | 04:05 PM
Best4x4's Avatar
Should have just popped the center cap off and removed it first. You could put the ebrake on and give it a shot as it sits.
Old Aug 26, 2020 | 04:24 PM
Brandon318's Avatar
Roger. Silly question I guess. It took an extra 15 minutes to re-do everything and guarantee I don’t break anything. Sometimes I’m dumb.
Old Aug 26, 2020 | 11:47 PM
JUKE179r's Avatar
Better to be safe than sorry mate.
Old Aug 27, 2020 | 08:00 AM
Sandman614's Avatar
Is that a ridiculously long bar or are you just happy to see us?
Old Aug 27, 2020 | 08:14 AM
frostythor's Avatar
if you do intend to do it, at least put a two nuts on your studs and the a bar across the studs to stop the whole thing turning, the nut are to stop the bar coming off the studs
Old Aug 27, 2020 | 10:28 AM
Brandon318's Avatar
Just put everything back together, put all it's feet on the ground, then waited for the wife to come home to lay on the brakes. Easy and safe.
discoguy96
Sep 11, 2015 06:01 AM
dusty1
Dec 15, 2013 07:48 AM
0304Disco
Nov 6, 2012 01:01 PM
Spike555
May 27, 2009 07:32 PM
mrossipir
Jan 1, 2009 10:54 AM
