Am I looking at a full bottom end.
Old Nov 6, 2015 | 12:59 PM
thesoundguru's Avatar
Default Am I looking at a full bottom end.
So I pulled the sump and front cover toady to find out just how bad the oil pump self destructing was. I was glad to find the front cover fully intact so I thought I was just looking at a oil pump gear set and call it a day. Then When I was cleaning up I noticed the guide on the crank was wore down during the ordeal. So my question is, can the guide itself be replaced or am I looking at having to replace the crankshaft. I am really kicking myself right now because I should have changed the oil pump gears last year when I did the front cover job to fix my coolant leak.
Old Nov 6, 2015 | 01:13 PM
Fast951's Avatar
What do you mean by the guide on the crank? Maybe post a pic so we can help you...
Old Nov 6, 2015 | 01:15 PM
The guide that the timing chain, harmonic balancer and oil pump are driven by on the crank.
Old Nov 6, 2015 | 02:08 PM
Fast951's Avatar
Gotcha. I believe that is a key that sits in a relief in the crank end. If it is now flush you may have sheared the key. You may be able to tap out the bit that remains in the crank end and get a replacement key.
At least this is how I remember it.
Get ready to find more destruction in the top end if the timing chain and gears stopped moving but the pistons didn't.
Good luck.
Old Nov 6, 2015 | 02:10 PM
Dave03S's Avatar
Dang! I thought this was going to be another one of those Wheel Size threads!!
Best of luck!
Old Nov 6, 2015 | 02:30 PM
Fast951's Avatar
Key, Crankshaft Chainwheel P/N = ERR2846
Old Nov 6, 2015 | 04:08 PM
The timing chain was still intact, I just replaced that when I did the front cover.
Old Nov 22, 2015 | 12:06 PM
Anybody have any advice on getting the woodruff key out?
Old Nov 23, 2015 | 06:06 AM
drowssap's Avatar
hammer & punch
Mountain Goat
Mar 31, 2011 01:10 PM
Rover Curious
Jul 22, 2009 10:48 PM
kraelo
Mar 19, 2008 05:06 PM
ste.s
Feb 14, 2008 10:35 PM
telly
Mar 27, 2007 04:25 PM
