Amigo trouble codes 047, 067
Old Jan 28, 2013 | 05:00 PM
Disco Fuego's Avatar
Default Amigo trouble codes 047, 067
Hello all,
I had been driving around with my dash lit up for a few weeks and was offered to use a fellow DII driver's scanner. I of course gladly accepted the generous offer and plugged in the unit Friday afternoon roughly 3.2 seconds after the delivery by UPS.
The code I received was 067. The lights cleared. Me happy and thinking that this probably means replacing the sensor Rear Right. Correct?
The lights stayed off while driving home and the next morning. But then on Saturday they did appear again after I did a brief 30 second drive through a very muddy parking lot. (The truck was too clean, so I decided to make it look prettier...). I parked the truck, did some shopping and when I came back and started it back up, the lights had disappeared again. At home I decided to plug it in again and got the following results:
1.--Current Faults---->
Active Faults:
None
Logged Faults:
None
<-END Faults
..--Previous Faults--->
Active Faults:
None
Logged Faults:
047:Rear Right sensor output low
067:Rear Right sensor electric fail
<-END Faults
Active Faults:
None
Logged Faults:
Rear Right Sensor Bad Output
<-END Faults
So here are my thoughts (and they may be totally wrong which is why I turn to you for excellent advise and feedback):
-067 Bad Output / Electric Fail ---> The sensor needs replacement
-047 Out put low ---> There is some electrical short / moisture in the wire or sensor. Does not mean sensor needs replacement, but rather I should inspect the wire for damages, clean everything well and see if code returns.
Your feedback is, as always, greatly appreciated.
Thank you!!
Old Jan 29, 2013 | 12:52 PM
Sorry, bump...
Old Jan 29, 2013 | 09:16 PM
Another bump...
What to do with code 47 & 67 ?
What documentation can I find this in? It's not in RAVE and searching the posts did not give me a conclusive answer either...
Old Jan 29, 2013 | 09:34 PM
exploringnh's Avatar
I would replace the sensor.
Matt_Attack352
Jan 13, 2014 09:55 AM
driscoii
Dec 26, 2012 05:14 PM
BajaXJ92
Dec 3, 2009 07:43 PM
Princess
Jul 4, 2009 12:24 PM
