Amigos (4) back. Option B seems solid
Good for about 5 miles then, ding ding ding.
I’m looking at getting the axle seals replaced both sides. One is much worse than the other.
Considering swapping that hub while I’m at it.
Unless. Leaky axle seals could be compromising that sensor? Hmm.
Swapped out the front axle seals which had been leaking for months..
I think because the bearings were worn, which was likely causing the 4 Amigos.
New hubs, bearings, sensors.. and seals.
Either way, all that swapped out and the Amigos are banished.
Pity it was the expensive route.
I’m mostly glad that my gear oil isn’t flinging itself all over the place.
LA_Disco2
Oct 24, 2023 10:43 PM
austinlandroverbill
May 17, 2017 06:40 PM
