Amigos (4) back. Option B seems solid
Old Dec 6, 2023 | 02:36 PM
Harvlr's Avatar
Disconnecting and reconnecting a plug often gets rid of faults, especially when there are electronics involved.
Old Dec 9, 2023 | 11:41 AM
cappedup's Avatar
Originally Posted by cappedup
I’ve looked at the wiring I can see, between sensor and SLABS. Pulled the connector, looked at it, blew on it, put it back in and waggled it around…. Fingers crossed the same gremlin that was in yours, just left mine.
Good for about 5 miles then, ding ding ding.
I’m looking at getting the axle seals replaced both sides. One is much worse than the other.
Considering swapping that hub while I’m at it.
Unless. Leaky axle seals could be compromising that sensor? Hmm.
Old Jan 6, 2024 | 12:20 PM
cappedup's Avatar
Swapped out the front axle seals which had been leaking for months..
I think because the bearings were worn, which was likely causing the 4 Amigos.
New hubs, bearings, sensors.. and seals.
Either way, all that swapped out and the Amigos are banished.
Pity it was the expensive route.
I’m mostly glad that my gear oil isn’t flinging itself all over the place.
LA_Disco2
Oct 24, 2023 10:43 PM
austinlandroverbill
May 17, 2017 06:40 PM
Boats121
Jan 2, 2015 08:31 AM
rappo999
Feb 25, 2013 08:52 PM
joatman
Jan 11, 2011 08:39 AM
