Annoying Fan sound when heat is turned on
Old Nov 8, 2009 | 02:18 PM
Aj6543's Avatar
Default Annoying Fan sound when heat is turned on
When I turn on my heat, I hear this annoying fan making sound behind the glove box. How do I fix this?
Old Nov 8, 2009 | 02:48 PM
That is you interior blower motor, better get used to it, unless it is noisy because it's failing, otherwise that is your only interior fan motor.
Old Nov 8, 2009 | 04:34 PM
lipadj46's Avatar
If it is too noisy you can remove it squirts some oil in there and gain another couple years from it.
Old Nov 8, 2009 | 04:53 PM
Aj6543's Avatar
Its making noise, but bearable. Does that mean it needs to be replaced? Is it difficult to replace?
Old Nov 8, 2009 | 05:10 PM
You may have sucked some junk up into the blower cage, if so it can be cleaned out, or the motor is starting to fail and will let you down over the next short while.
Yes, if you are a little mechanical, you can replace it yourself.
Old Nov 8, 2009 | 06:44 PM
Urban Panzer's Avatar
Migth have got a leaf or 2 in the motor and it hits the fan when it spins, had this on a friends car. You can simply remove the fan cover of the motor and have a look.
joe black
Oct 31, 2014 11:51 AM
jmason
Nov 17, 2013 06:39 AM
aarongregor
Jan 16, 2012 11:43 AM
joey2mak
Jun 8, 2010 07:17 PM
marlymarl
Oct 16, 2008 07:21 PM
