Another coolant leak question
Sorry to add to the coolant / HG topics already here, but I am not certain about what the issue is. I have a coolant leak (no doubt) pressure test / drop in reservoir confirm, but i cannot find the leak - it drips off the rear underside of the engine / transmission.
Would this be the HG for sure? OR is there a chance it is something else that may have come loose? I had leaky valve covers due to loose bolts.... is there something that may cause the same for the cooling systems (intake manifold)?
Last part to the question... can you nurse a coolant leak. I have tapped out the budget for the yr, so can't afford to do the HG for a while. I am loosing about a half - cup of coolant every week or so. My worry is that I read on one of the threads here that if the leak is bad enough there can be air introduced into the system and cause a bubble increasing the risk of damage to the engine.... is this true?
Here is where the coolant leak shows up:
Thanks for the help Cheers
Clint, post up what you find out. I have the same leak and was told it's an intake manifold leak by the shop when I had them do the timing cover work. I've been checking the overflow tank daily and topping it up, but I need to take action. I wish I was in SoCal; there's a guy on CL who specializes in doing HGs on the Rover V8s for a flat $800 + parts.
ZMonet
06-24-2016 04:00 PM
