Another coolant leak question
Old Dec 8, 2014 | 10:14 AM
clint70's Avatar
Default Another coolant leak question
Sorry to add to the coolant / HG topics already here, but I am not certain about what the issue is. I have a coolant leak (no doubt) pressure test / drop in reservoir confirm, but i cannot find the leak - it drips off the rear underside of the engine / transmission.
Would this be the HG for sure? OR is there a chance it is something else that may have come loose? I had leaky valve covers due to loose bolts.... is there something that may cause the same for the cooling systems (intake manifold)?
Last part to the question... can you nurse a coolant leak. I have tapped out the budget for the yr, so can't afford to do the HG for a while. I am loosing about a half - cup of coolant every week or so. My worry is that I read on one of the threads here that if the leak is bad enough there can be air introduced into the system and cause a bubble increasing the risk of damage to the engine.... is this true?
Here is where the coolant leak shows up:
Thanks for the help Cheers
Old Dec 8, 2014 | 10:55 AM
drowssap's Avatar
if you can see it, you can find it with a pressure tester. Could be HG, Intake gasket or freeze plug. I suggest clean the engine good borrow a pressure tester and a mirror again.
Old Dec 8, 2014 | 12:16 PM
Dave03S's Avatar
If you verify that it is a HG leak, yes you can nurse it along by doing what you are already doing, watch and keep your coolant level topped off at all times.
Old Dec 8, 2014 | 04:12 PM
sdhow's Avatar
Clint, post up what you find out. I have the same leak and was told it's an intake manifold leak by the shop when I had them do the timing cover work. I've been checking the overflow tank daily and topping it up, but I need to take action. I wish I was in SoCal; there's a guy on CL who specializes in doing HGs on the Rover V8s for a flat $800 + parts.
meltdowndave
Oct 12, 2017 12:27 PM
ZMonet
Jun 24, 2016 04:00 PM
G Reeves
Feb 21, 2012 02:39 PM
rick.miles
Freelander
Dec 20, 2008 06:21 AM
zerochills
Jan 21, 2008 08:42 AM
