Another Door Locking issue
Old Jul 10, 2017 | 07:28 PM
Davis31052's Avatar
Default Another Door Locking issue
So, I did a search here and all I can find are issues with the doors not unlocking. My issue is the reverse. My doors won't lock.
The alarm will set with both the lock button on the key, and by inserting the key and turning the drivers door lock cylinder, however none of the doors will lock. I can push the dash mounted lock and hear a relay clicking under the steering column but none of the door motors work.
CDL unit maybe?
Old Jul 10, 2017 | 07:57 PM
Twix's Avatar
Check the wiring at the body control module. If none work, that's where I'd start. You should be able to hit the lock button on the remote as well as the inside button and there should be voltage at those pins. Also, just for sake of simplicity, check the relay itself. If you hear a click, be get no action, it might just be a worn relay.
nate2k5
Jun 3, 2012 05:49 AM
rellik1103
May 16, 2012 01:05 PM
russoaks
Jan 5, 2009 03:38 PM
johanba
Apr 3, 2007 11:37 AM
