Another FAST TURN SIGNAL thread -this time regarding only when attached to a trailer
Old May 23, 2014 | 06:35 PM
ImQuattro's Avatar
Default Another FAST TURN SIGNAL thread -this time regarding only when attached to a trailer
So I wired in a universal trailer wiring harness as per http://www.discoweb.org/trailerwire/index.htm and when I hook up to my trailer, on which the lights all work and don't cause this issue in other vehicles that use the trailer, the Rover's lights and trailer's lights all flash double time, either when on as a turn signal or 4 way (hazard).
Unhook the trailer, and the Rover's lights work fine and flash at their normal pace.
Interestingly, if I have the 4 ways or turn signals on with the trailer attached, and depress the brake pedal, the pace reverts to normal speed. Release the brake pedal and back to double time.
Thoughts?
Old May 23, 2014 | 08:15 PM
Externet's Avatar
Are the trailer lamps incandescent or LED ?
LED bulbs (much lower current) can confuse the on-board compfuser.
Old May 24, 2014 | 07:02 AM
ImQuattro's Avatar
Yes, LED. Can a heavy duty flasher relay be installed?
Or am I just relegated to use non-led lights?
Old May 24, 2014 | 07:44 AM
abran's Avatar
Go to superbrightleds.com
They sell load resisters that you attach inline on the LED lights.
They also sell flasher relays, but I can't tell if they will work on a rover.
If you find one that works, please post the part number.
Old May 31, 2014 | 09:31 PM
Externet's Avatar
Sorry for the delay.
A heavy duty flasher will do nothing. The on-board compfuser senses the little current from LED bulbs and thinks a bulb is burned and warns the driver with double frequency. Normal behavior.
An in-line series resistor will do nothing.
A resistor in parallel with the LEDs will correct the problem but it is a waste of heat and complexity and reliability, and counteracts the convenience of LEDs.
I would stay happy with the fast blinking when trailering and ignore correcting it.
Old May 31, 2014 | 11:14 PM
ImQuattro's Avatar
My fix was to install standard bulbed trailer lights while I was redoing my trailer.
$22 on sale & 20% discount at Harbor Freight. Can't beat a full set of lights and wiring harness for less than $19!
dogparc
Jan 3, 2012 04:38 PM
Prowler9876
Feb 21, 2010 07:32 PM
robfrey
Oct 27, 2007 06:40 PM
LordOphidian
May 30, 2006 03:00 PM
