Turn signal blinks fast when I apply the brake
Old Feb 21, 2010 | 06:09 PM
Prowler9876's Avatar
8th Gear
Default Turn signal blinks fast when I apply the brake
Any ideas on this one?
When I step on the brake pedal, the left turn signal blinks fast (like a bulb is burned out). When I step on the brake pedal with the right turn signal on, it blinks at the normal speed.
Thanks in advance
Old Feb 21, 2010 | 06:38 PM
antichrist's Avatar
Sounds like you have a ground problem with your left brake light and it's feeding through the left turn signal.
Old Feb 21, 2010 | 06:42 PM
I have the EXACT same problem, but since it is winter I just have not addressed it yet.
It is the turn signal bulb holder in the rear bumper, it does not have a good connection and the extra drain of the brake lights on the voltage makes the turn bulb loose power.
Have a friend turn on the left turn adn hold his foot on the brake while you push the connector into the bumper turn signal, it will blink normal until you let go.
I have just stopped using my left turn signal until spring.
Old Feb 21, 2010 | 07:32 PM
bikingteacher's Avatar
That's fine just go around the block enough time to make all rights until spring. It will be like $1,000 in gas, but at least you won't get cold!
BIG
Feb 8, 2010 11:46 AM
JBEGIN
Aug 9, 2009 11:58 AM
LordOphidian
May 30, 2006 03:00 PM
