Another leaky roverII
Old Feb 13, 2017 | 08:10 AM
Luckyjayb's Avatar
True and you can always smear a little wd40 on the next of the water pump or white lithium grease to make it slide on easier. If you didn't take the fan off, it can be a major pia to try and fit it properly and properly secure it in there
Old Feb 18, 2017 | 11:27 AM
project_68's Avatar
Originally Posted by mln01
I wouldn't yet say that the new hose itself is the problem. It would be inlikely that a new hose would leak right away
So, finally got the time to crawl under the rover this morning w/ a flash light and some safety glasses to identify the source of the leak. After removing the fan, shrouds, and belt, and using a rag to follow the drips upstream I was able to identify the source. Although I can't actually see the source bc the water pump pulls is in the way, my best guess is that it's coming from the wp pully seal, and produces a constant drip, drip even when cold. When running and or at temp, it's a steady stream.
Is the wp pully seal a service item, or do I have to replace the wp as a unit?
​​​​Thx.
Old Feb 18, 2017 | 11:33 AM
Friday Night Disco's Avatar
Not sure if you can fix your existing but, I would recommend replacing the pump and gasket to avoid future failure
Let me rephrase my feedback...If you are going to replace the gasket, might as well do the pump so you know you have a good one on there that is not a time bomb.
FlyingZebra34
Apr 18, 2014 02:00 PM
jdwilks
Jul 2, 2013 10:16 AM
dillhole
Nov 12, 2006 03:35 PM
Benhamtroll
Jun 21, 2005 09:41 PM
DIMISA1977
Apr 20, 2005 09:33 PM
