Another lift kit question for you.
Old Jun 21, 2009 | 05:02 PM
mowermechanic's Avatar
Default Another lift kit question for you.
A 2 inch lift is the maximum lift for a D1 without changing drivelines, brake lines and getting really expensive. Is that accurate? And for companies, I know old man emu, and rovertym are reputable, but what about www.toddcosuspensions.com?
Old Jun 21, 2009 | 05:23 PM
AK Rover's Avatar
You can go up to 3" without getting too expensive. IF you really plan to wheel your vehicle with a 3" you'll probably want to spend the money for the upgrades like RTE offers so that you don't run into problems in the future. I can tell you that the RTE rear links are a good idea even with a 2" lift. I'm fighting what I believe is my driveline binding because one of my rear links got bent off road causing my rear axle to be out of alignment.
Old Jun 21, 2009 | 11:18 PM
So springs, shocks, front radius arms and rear links? No brake lines or driveline alterations? I just want 33''s. My main concern is castor alignment, and how big a deal is it?
Old Jun 21, 2009 | 11:20 PM
hazletbassist89's Avatar
Nope. You should be good to go with that. If you have a rotoflex consider changing to u joint, but it doesn't need to be done right away unless your rotoflex is destroyed all ready (doubt it)
Old Jun 22, 2009 | 10:33 AM
No radius arms, at least till you see how bad you might track with whatever lift you use, no rear trailing arms, at all. I would suggest checking your rubber brake hoses, if they are original, I would change them before one pops, as for the drive line, 3"s on most D1's will mean at least a front drive shaft with a double cardon housing.
Do it in steps so you don't spend more then necessary.
Old Jun 22, 2009 | 03:35 PM
Thanks you guys, makes sense. 2" would fit 33" maybe with light trimming?
Old Jun 22, 2009 | 05:48 PM
OH yes, and be cheaper also.
Old Jun 22, 2009 | 10:45 PM
Awsome, thank you. The hardest part was to get a plan together, now I can get the plan into action!!
jycsalas
Jun 21, 2022 01:44 PM
caymandrew
May 9, 2015 10:05 PM
Bostonc16
Mar 7, 2015 10:32 AM
calebbo
Oct 12, 2011 09:54 PM
jycsalas
Sep 16, 2008 01:20 PM
