Another P0308 Misfire Post
Old Mar 10, 2018 | 06:55 PM
  #21
SiracHaile's Avatar
Update:
Replaced wires with Magnecor 8mm wires. Replaced spark plugs to Bosch Platinum+4 plugs. Replaced coil packs with new Bosch oem. Replaced fuel injectors with reconditioned replacements. And..... still cylinder 8 misfire.
At this point I’m thinking it’s something not related to anything with ignition or fuel or compression but possibly electrical or worse the engine.
I’m so lost now I’m clueless. And again this is only at startup. Anything else I need to check?
Old Mar 10, 2018 | 10:33 PM
  #22
Saturnine's Avatar
How were the O-rings on the new injectors? Injector wiring look ok?
Old Mar 10, 2018 | 10:59 PM
  #23
SiracHaile's Avatar
All looked brand new. Injector harness looked fine no cracks or broken insulation. After looking into it more and doing more research cars that have this issue have head gasket leaks. So even though it’s all rebuilt, I’m going to pressure test the cooling system. This is becoming a nightmare....
Old Mar 21, 2018 | 03:47 PM
  #24
stxscott's Avatar
Please keep us updated on what you fine - I've got the intermittent 308 as well, but I haven't changed coil packs yet.
Old Mar 21, 2018 | 03:52 PM
  #25
Dave03S's Avatar
You can look into cyl 8 with a cheap ebay boroscope attached to your smartphone. That would at least rule in or out any HG issues there.
Old Mar 22, 2018 | 12:14 PM
  #26
SiracHaile's Avatar
Sorry for the lack of updates. I have done an internal check with a borascope while pressurizing the coolant system with 1.25 bar of pressure. I didn’t find any leaks in the cylinder. This was done at operating temperature. I also discovered if I hold the throttle at 2000rpm during startup SAI the misfire doesn’t happen. I did that for a week until all my monitors were completed to pass smog. Next morning didn’t do that and the SES light came on. So it may also be a vacuum leak on the cylinder maybe the gasket isn’t fully seated. I need to do leak down to see if the valves are fully seating or try a vacuum leak test.
stxscott
Jan 27, 2018 09:45 AM
jamieb
Feb 7, 2016 07:45 AM
Summitdog
Feb 16, 2012 09:20 AM
stream25
Jan 23, 2010 12:09 AM
