Any issue move the oil pressure switch here?
Old Feb 19, 2022 | 12:46 PM
Brandon318's Avatar
Default Any issue move the oil pressure switch here?
The switch for the dash gauge I’m installing just barely won’t fit with the alternator bracket installed, so I moved the main switch up a spot and moved the dash gauge’s switch to it’s spot. No issue, right?
They barely fit, but fit nonetheless
Old Feb 19, 2022 | 03:55 PM
redwhitekat's Avatar
Is that where the oil cooler lines would go. ? If it is you might get the oil light. I just went through this with my 2004. When the weather got cold I was reading 0 psi at idle there is a valve or something in there that closes when it’s cold
so not a good spot for anything but a oil cooler
Old Feb 19, 2022 | 04:17 PM
Best4x4's Avatar
It's usually a silver plug in that hole, but I could have sworn the threads were different vs the oil pressure switch threads. Might be thinking of an earlier front cover though. I don't see any reason it wouldn't work as long as the thread is the same.
Old Feb 19, 2022 | 04:56 PM
Brandon318's Avatar
No, oil cooler lines are down below.
Old Feb 19, 2022 | 04:57 PM
Brandon318's Avatar
No, you're right, the threads are different but that brass bit is an adapter.
Old Feb 19, 2022 | 11:42 PM
Discorama's Avatar
I always wanted to do that (I have the adapter already), in order to get rid of the sandwich adapter. How much effort is it to remove the alternator bracket?
Old Feb 20, 2022 | 10:06 AM
Brandon318's Avatar
Very little. Just remove the fan and shroud, belt, the idler pulley, the alternator, and then the bracket is just a few bolts. About an hour.
jvarnadoe
Jun 17, 2021 09:03 PM
grahamggggg
Dec 1, 2020 07:19 PM
dicksoutforharambe
Oct 8, 2017 07:34 PM
Matt927
Jul 5, 2016 09:03 AM
mjbrox
Dec 10, 2014 09:35 PM
